Best gaming monitor for my situation?
GhengasKhan
Looking for the best monitor for me.
i have a 2080 super and right now am using a 144hz 1080p monitor but am looking to upgrade it. Suggestions?
main use is gaming. Looking to stay below 500$ US but can work if the deals right.
What are the rest of your specs? 2080 Super should be able to handle 1080p 144Hz no problem.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
It handles it fine, I’m looking to upgrade, I want a better monitor, I’m running an i7. 7700k 16gb ddr4 ram and I have a asus z270E gaming mobo
edit: I was looking towards a 1440p or so
LG GL-850.
It's $500, 144Hz 1440p, IPS, has Freesync so it'll work with both Nvidia and AMD, also has surprisingly good color once calibrated. I use one at work, it replaced an old (and expensive) NEC 60Hz color-accurate-for-the-time 1440p IPS. The 144Hz is really helpful for eye-relief.
LG 27GL850 27'' UltraGear™ Nano IPS 1ms Gaming Monitor with G-Sync® Compatibility (27GL850-B) | LG USA
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
Sorry I misunderstood.
I think my brain misplaced the modifier to read like this:
 "I have a 2080 super and right now...derpy derp... but am looking to upgrade it. Suggestions?"
Stupid brain.
Here's a list of options you might consider:
https://pcpartpicker.com/products/monitor/#r=256001440&D=144000,360000&sort=price&A=2,4,3,1,6,5&P=6,2,7,3,5,4&G=100000000000,5000000000000&X=0,55092&B=350,1200
BabyBlu (Primary):
BigBox (HTPC):
  • Display: None
NAS:
  • Synology DS216J
Stupid brain.
No big deal at all I work long tedious random hours so my brain does the same 🤣 thanks I’ll check them out
This new Lenovo is really good option. And while the LG GL850 recommended above isn't a bad monitor either, the lenovo is slightly better for the same price.
https://www.rtings.com/monitor/reviews/lenovo/legion-y27q-20
https://www.rtings.com/monitor/reviews/lg/27gl850-b
Play around with this table tool to search for more options. You can add more filters from the add column button.
https://www.rtings.com/monitor/tools/table/43435
And lastly, I would recommend you read the sticky as it has lots of good information that will help you understand the reviews.
I’ll check them out and yeah I browsed that a little, I’m terrible when it comes to displays and such which is why I ask, get a few opinions and such and then look up reviews and stuff to make a choice.
Seems like the 27" Samsung G7 on sale for $550.
https://www.rtings.com/monitor/reviews/samsung/odyssey-g7
It's the best VA panel out there, but the curviture is really agressive. It also had some problems with quality control, but some people here have said those things have been fixed.
I guess the Samsung G7 will be a good match for your 2080 Super. I own the Lenovo Y27Q-20, and it is working really good for me, but if I am still thinking on getting a 1440p - Since it is the sweet spot -  I will choose the G7 for sure.
Nature Respects Resistance.
For a 1440p panel, I really like the LG GL850. IPS means you're getting accurate color, none of the dark stuff VA panels have, and none of the crappy viewing angles that TN panels do.
I have the 1080p version of the GL850, the GL650, and it's surprisingly good for a 27" 1080p display with little to no screen door effect, and calibrated color that's within spitting distance of my NEC PA272W I use at work.
I prefer IPS too, But I think the G7 with its QLED Technology may surpass some of the best IPS panels available in the market.
