Do I have my fans oriented in the wrong way?
Solved by AzrealNoctis,
1 minute ago, Jumballi said:Usually the way with pc case fans is the side the sticker is on is the direction the air is outputted towards, and for RGB fans you'll notice that the RGB lines up if you line the stickers up.
I seems to have gotten it to work properly by rotating the bottom fan counterclockwise and then reversing the fan led order in icue
