Hi guys, will 240hz and high response times help with clarity in motion, ei looking around in game things are blurry when moving the mouse
I currently have a ips 144hz panle 4ms response time but I’m looking at a 240hz va panle with 1ms
the only reason I want to upgrade is for being able to see better why the camera is moving
what are your thoughts
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1275073-clarity-in-motion/
Clarity has a lot do with the technology you use.
That is why I moved to OLED for 4k gaming.
This video shows it better than I can explain it.  https://www.youtube.com/watch?v=x9n8Hz_RLqw&t=637s
I am not going to get games like Assassin's Creed Valhalla much over 60 at 4k so OLED is the answer for me now.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1275073-clarity-in-motion/#findComment-14257114
Its one part of it for sure.
one of the newer 'fast' IPS displays is ur best bet in that regard. Or better yet, a OLED (TV only, 48" smallest)
You also need to ensure you have any in game motion blur disabled.
There will always be an amount of blur present, persistence blur of the 'sample and hold' technique used by modern displays, BFI can be used to mitigate it but that in itself comes with its own issues when combined with LCD tech, strobe crosstalk (image duplication).
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1275073-clarity-in-motion/#findComment-14257119
Yeah, it definitely can help with it, a modern 240Hz panel will improve it. There are high end OLED 4K 120Hz TVs but they're still 120Hz and they're huge. So yeah...
We're in weird spot for now, before MicroLED actually comes to consumer market.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
https://linustechtips.com/topic/1275073-clarity-in-motion/#findComment-14258807
I wish they would just make a bad boy 1440p crt monitor and just work on that tech as it was miles better than what we have today
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1275073-clarity-in-motion/#findComment-14258841
