Aio and a hybrid card
Rip_in_pepperoni
I have a corsair 4000x, and an h100i v2 (240mm) on my 10600k. I want to soon get an evga hybrid rtx 3080, which also has a 240mm radiator. My question is, seeing as I have to mount one in the front and one at the top, is my best bet putting the gpu rad in the front and the cpu rad at the top? Or vice versa? Looking for the best all around temps for the system. The top will be the exhaust, as well as the rear, and the 3 front fans will be intakes as of right now. Any response would be great, thanks!
The GPU is going to crank out a lot more heat so I'd want that to exhaust out of the case.
"And I'll be damned if I let myself trip from a lesser man's ledge"
Should I maybe make the top rad an intake too? Then I could also have positive air pressure, pushing dust out of the case.
