CPU Cooling and FAN for Case
Alex Georgiou
I need your help about on the CPU cooling and FAN for PC case.
From CPU cooling brand I am between Corsair, Zalman, CoolerMaster, Be quiet, NZXT, Noctua . What shoud I notice to get a very good cooling from specs and quality? I also want it to be quiet and it cool the system very well
From a platform I am between Intel and AMD. But I quote the parts that I will get either Intel or AMD.
Finally I would like you to tell me what to notice in general from the cooling for the CPU and for the FAN of PC case.
Intel
CPU: i9-10900K
Motherboard: ASUS ROG MAXIMUS XII FORMULA ή Gigabyte Z490 AORUS ULTRA G2. One of two.
RAM: G.SKILL F4-3600C16Q-32GTZN
CPU Cooling: ?????
Graphic Card: Nvidia RTX 2080Ti
Storage Primary: Samsung 970 EVO Plus NVMe M.2 SSD 2TB
Storage Data 2o: WD Blue SN550 NVMe SSD 2TB for project_files and sources footage.
Storage Data 3o: HDD 4TB Backup
PC Case: Full Tower will be but I haven't looked for yet.
PSU: 1200W Fully Modular will be but I haven't looked for yet.
AMD
CPU: AMD Ryzen Threadripper
Motherboard: ASUS ROG Zenith Extreme or Gigabyte X399 DESIGNARE EX. One of two.
CPU Cooling: ?????
Storage Data 3o: HDD 4TB για backup
what are these builds for? what is your use case? do you have them already or are you trying to chose between them?
I would go for be quiet! dark rock pro 4 CPU cooler and be quiet! silent wings 3 fans.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
(CPU cooler ) fans should put much air through them and be quiet...
The bigger the fan, the lower the noise because it can transport more air with less rotations per minute.
And a slow fan is a quiet fan.
So 140 mm fan are usually better than 120 mm fans if your case offers enough space.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
I want to buy a new pc and I don't decide which of the two will I buy.
I ask here what to look out for when buying cooling for CPU.
@suedseefrucht Okay. I thought to buy this iCUE H100i RGB PRO XT Liquid CPU Cooler. Won't be it okay my system, If I buy this?
I ask, because I would want to know so that I learn :).
they are pretty different systems. the 10900k is for high end gaming and editing, while the threadripper is a workstation machine.
this is why I'm asking what you're planning to do with it. also, the 2080ti is not a good buy, given it's price. a 3070 has the same performance for half the price. i think you need more advice and guidance than just what fan and case to use, but you need to give us some information on what you're trying to achieve with this build, what your budget is and the country you're buying from.
You are right for 3070. I thought that it cost very much.
