Link case fan speed with GPU temps?
Is it possible to have my case fan speed ramp up whenever the GPU gets hot? Whenever I play games on max settings my 3080 goes to like 75-78 degrees (that's with my GPU fan curve at 85% speed btw), I have an NH-D15 so I never have to worry about CPU temps.
I heard it was possible on SpeedFan to link fans to GPU but that program no longer works, so what can I do, is it possible?
https://linustechtips.com/topic/1273663-link-case-fan-speed-with-gpu-temps/
See if the fans on your GPU directly connect via wires or a cable. If a cable, see if you can get a splitter.
Make sure that the correct wires connect.
Alternatively, you could rig up a temperature sensor + raspberry pi zero + 5V to 12V voltage converter + PWM fan.
Use some PWM software, a script (set to autorun on startup), said voltage converter, and temperature sensor close to your heat sink.
Fun project!
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
Fun project!
okay i'll look into it thx
Fancontrol is a great substitute for speed fan.
You could also get a corsair commander pro. Which you can do this using the icue software.
I wouldn't go splitting wires I but if you want to be fancy. Remove the shroud and fans from the gpu replace with 2x 120mm fan(zip tie them on). Grab a crj 3 way own fan splitter and a fan that has data power. Connect the 2x 120mm to the splitter and the extra lead to the fan hub as the control. Connect the case fans to the hub.
