GPU won't work for Folding@home
Solved by Whaler_99,
If you do know how to isolate the Log (checkmark so it only shows the one you want) copy and paste it here, that way we can go through it all.
As for deleting/adding - if you click the Configure you can then go into the Slots tab, choose the GPU on and delete it. Save and reboot system. Go back into Configure, slots, Add - check the radial button for GPU, leave all defaults. Save. GPU slot should be back, give it a few hours...
Share
Followers
3
