I'm going to use an ASUS Strix X570-E for my next build, and I need some help with my fan headers.
I'll be using it with a Phanteks P400A-Digital (3 ARGB fans) and a Noctua NHU12S (just the included 1 fan)
The manual mentions the following headers: (manual, page 1-18)
Obviously, the Noctua goes into the CPU_FAN and 2 case fans go into the CHA_FAN headers. Where do I plug in the third case fan?
Is the M.2_FAN header okay to use?
https://linustechtips.com/topic/1271492-asus-x570-e-fan-headers/
1 minute ago, lugs said:
Thanks a lot! Are there certain brands/models of splitters I should look out for, or does it not matter?
quote or @AndreiArgeanu people for them to see your reply, get anyone from a known brand and you will be fine, corsair makes good ones
2 minutes ago, AndreiArgeanu said:
Any basic PWM splitter with good reviews should do. They're about 3$ or so.
Thanks a lot for the insight! :)
