Budget (including currency): 96,000 INR(Indian Rupees)
Country: India
Games, programs or workloads that it will be used for: AI, GTA V and other standard and similar game.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Planning to buy a new PC as it's my first build, like genienly researching before I purchase it. My specs is planned as followed -
System Builder - Ryzen 5 3600 3.6 GHz 6-Core, GeForce RTX 2060 6 GB, MasterBox Q300L MicroATX Mini Tower - PCPartPicker
I believe I can get a little heaper, or get more efficient with nearby budget of not exceeding the max limit of 85k. I need suggestions. If you're not from India, please use amazon.in or Newegg's Indian price as currency for suggestion. Thank you!
Edit - I just updated my build with more realistic pricing for CPU and some changes as per budget. I just realized that my case Cooler Master MasterBox Q300L MicroATX Mini Tower Case is not available on Amazon.in anymore so I think I'm gonna need a new one. Can someone please suggest me a good case and check to see if my setup is good enough? Thanks.
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/
Looks good. In most Asian countries, AMD sells a 'Ryzen 5 3500'. It's a 3600 without hyperthreading, but for half the price. Performs the same in games.
You really don't need 32GB of memory either... 16 is more than enough.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14225498
Good case and some additional fans to mount on the top for additional exhaust.
Better psu.
Better gpu. For 4k rupees more you get a little more performance, rgb and much better cooler.
Better storage.
Better ram choice.
Much better motherboard.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14225532
Build this instead, better and cheaper...
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (₹16000.00)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard (₹7398.00 @ Amazon India)
Memory: ADATA XPG GAMMIX D10 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (₹5999.00 @ Amazon India)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive (₹4999.00 @ Amazon India)
Video Card: GALAX GeForce RTX 2060 6 GB Video Card (₹27999.00 @ Amazon India)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case (₹4399.00 @ Amazon India)
Power Supply: Antec Earthwatts Gold Pro 550 W 80+ Gold Certified Semi-modular ATX Power Supply (₹6849.00 @ Amazon India)
Total: ₹73643.00
Generated by PCPartPicker 2020-11-19 13:27 IST+0530
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14225616
40 minutes ago, SavageNeo said:
Both 2060 and 5600xt are similar in performance. 2060 is faster in certain games while 5600xt is faster in some games. Also, 2060 is available for ₹4000 cheaper than the cheapest 5600xt in india. So, 2060 would be a better buy for him.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14225621
16gb is way too low for ML. Heck, even 32gb is not enough sometimes.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14226304
I don't know what ML is but if you're suggesting it uses up 32GB of RAM, I suspect you're not being entirely reasonable.
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14228724
4 minutes ago, Manal Shaikh said:
It's Machine Learning, used for AI Development.
Okay, yeah that's correct. I thought since he said 'AI, GTA V and other standard/similar games' he was referring to some game that he's abbreviated to 'AI'.
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14228742
Well my requirements are to work on AI development, play games like GTA V and similar games, web development, intensive workload during peak hours without lag to avoid any productivity interruption. Like, I should be able to switch from gaming to work asap without any lag or something like that. I hope you understand. That is why I asked if my selections are good.
I was planning to get i5 10600k but then my friend recommended Ryzen 5 3600.
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14228747
I'd go for @VEXICUSbuild, but with 2x16gb sticks instead of only 2x8. Basically the same of yours, but cheaper and with a better PSU (don't ever go for a cheap PSU such as the ones from gigabyte).
Lenovo N23 Yoga
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14229536
I was thinking of making a new thread but let it be. I just realized that the case which I was planning to buy is not available on Amazon.in anymore and buying from Newegg is just gonna make the price 3-4x higher.
Read the edits in the main thread. Thanks!
Sorry for bumping like this if it's against the forum rule.
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14240574
Looks good to me.
Lenovo N23 Yoga
https://linustechtips.com/topic/1270899-my-first-ever-pc-build/#findComment-14240786
