http://uk.pcpartpicker.com/p/39ehg
Hey guys, wanted your opinion on the build and whether you can see any improvements for around the same price?
Also, if you guys know of any smaller mini itx cases that these parts would fit in please tell me because smallness is key for this build.]
Thanks!
My Rig - CPU: Intel i5 2500k - Motherboard: ASUS P8B75-M LE - Ram: 1x8GB Green Ram - GPU: ASUS Direct CU II 760 - Case: NZXT H230 - PSU: Corsair CX750M - HDD: 1TB WD Black -
"Since ancient times, the Dragon has been the only beast to equal the Tiger" -Ryuuji Takasu
https://linustechtips.com/topic/126984-mini-itx-build/
If you want it to be superrrrrrr small, then look at a Hadron, it has an integrated 500w psu, which is plenty. It's one of the nicest looking and smallest ITX cases.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688907
From the looks of things it should fit in this case http://uk.pcpartpicker.com/part/cooler-master-case-rc120akkn1
However it has a more acquired look to it.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688913
Sorry, but that case is well out of my price range.
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688920
Some of the Cooler Master cases are smaller than that (Elite 110, 130, etc.) and they are cheaper.
The Prodigy is a bit larger than other MITX cases IMO.
Is noise going to be a factor?
MY CURRENT PC
 CPU: Intel Core i7-4770k COOLER: Noctua NH-D14 MOBO: MSI Z87-GD65 Gaming ATX RAM: G.Skill Ripjaws 16GB DDR3-1600 STORAGE: Samsung 840 EVO 120GB SSD and Seagate Barracuda 1TB 7200RPM HHD GPU: Gigabyte G1 Gaming GTX 970 SLI CASE: Fractal Design R4 PSU: EVGA 1000W 80+ Gold
PERIPHERALS - KEYBOARD: Corsair Vengeance K70 w/ Cherry MX Browns MOUSE: Logitech G500/M100 MONITOR(S): Acer H236HLbid (I want an Asus PB278Q) SPEAKERS: Some Cyber Acoustics $10 speakers PICTURES AND FULL PARTS LIST @ PCPARTPICKER - http://pcpartpicker.com/b/z4Pscf
"Don't get so caught up in trying to make a living that you forget to make a life."
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688922
If you want an m-itx build to replace your current one. Id just find a m-itx MB that supports your current i5-2500k. that thing still has a lot of life left in it.
This isn't replacing my current rig, it's for my brother :)
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688923
Noise is not too much of a factor, no.
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688925
i love the hardon hadron
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688928
Good, since my seagate drive makes this really annoying chirping noise.
Looks good overall though.  The Cooler Master, Lian-Li, or Fractal Design MITX cases are all smaller than the Prodigy.
MY CURRENT PC
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688963
In that case. I would really try and save a little more and get the low end i5. even though the i3 is still pretty good id def get the Intel Core i5-4440 because its a true quad core.
you can offset the cost of that CPU with a cheaper case.
http://uk.pcpartpicker.com/p/39f5E
I did just that! thanks for the advice buddy!
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1688979
Thanks!
If you looking a small case. you could go for the Silverstone SG05
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1689138
What's the system used for?
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1689188
Just gaming and surfing the web really
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1689417
Are you limited to Amazon UK or are you open to other UK shops?
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1689569
The only other UK shop I am open to is scan.
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1697269
Would you not shop of dabs.com?
https://linustechtips.com/topic/126984-mini-itx-build/#findComment-1697334
