hello folks,
just a small question, with the new AMDs launching some of the Intels seem to be getting cheaper and so i was curious if you folks could tell me what the difference of the i7 10700k and kf skew processor is? i might be able to do an upgrade and since i havent gotten a confirmation back from NZXT that they got an am4 bracket available for my AIO i figured i might as well just consider an i7
thanks!
https://linustechtips.com/topic/1268546-difference-10700k-vs-kf/
KF doesnt have integrated graphics
dont change your cpu choice over a cooling bracket... just get a different cooler, or use the stock amd cooler (only the 5600 has one)
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
what motherbaord do you have now? if you do not have a b460/ z490 board AMD will be cheaper option.
If you do have, 10700kf willl be nice. 10700kf does not have intergrated gpu like 10700k. that is where the f comes from.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Does the F stand for press F to pay respects for integrated graphics
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
yes
the new AMD ryzen 5 costs 100 bucks more than an i7 10700kf, my nzxt x61 cost more than 100 bucks and is way prettier and more powerful than the stock amd cooler? how would there be any point in choosing the AMD system, even if its better  by like 10% its still significantly more expensive
i have Gigabyte Z97X-Gaming 3 with Intel core i5 4690k 4,7Ghz @1,35Vcore, i think the motherboard is too old for new Intel cpu
Whant country do you live? I can help you with this. well ryzen 5 5600x is likely not 100$ more since 10700kf need to be around 200-250$ then. that is used pricing.
and not to mention decent z490 board cost much more than board that can Handle AMD.
account in the price of a z490 board and vuala
the i7 10700kf is what, like 325? 250-350 z490 board, =~575-675
ryzen 7 5800x for $400, b450 board for $150-200= 550-600
you could get a scythe fuma ii with the money you saved (or bug tf out of nzxt)
AMD blackout rig
prices change all the time now amd ryzen 5 5600x 430€ : https://www.amazon.de/AMD-Ryzen-5-5600X-Box/dp/B08166SLDF/ref=sr_1_2?__mk_de_DE=ÅMÅŽÕÑ&crid=3AV1BTS4Q33IH&dchild=1&keywords=amd+ryzen+5+5600x&qid=1605251878&sprefix=amd+ryzen+5+5%2Caps%2C176&sr=8-2
intel core i7 10700kf 370€: https://www.amazon.de/Intel-Core-i7-10700KF-Basistakt-LGA1200/dp/B0883NG13L/ref=sr_1_1?__mk_de_DE=ÅMÅŽÕÑ&dchild=1&keywords=10700kf&qid=1605251913&sr=8-1
people buy AIOs for looks not for performance, even if the scythe were better it would not be an option
you need to factor in peoples personal preferences too, its like if a matching intel and amd cpu would cost the same but the AMD was 5% faster i would still tend toward intel because thats what i always had, but with the new amd cpu series i at least give it a thought that i might own an AMD some day
AMD blackout rig
thats funny
or you know, you could bug the absolute fuck out of nzxt support...
AMD blackout rig
Just now, Letgomyleghoe said:
thats funny
already did they said they dont have one in stock but i can ask again per email, i always responses within 24hours surprisingly
cheapest for 10700k
PCPartPicker Part List
Type Item Price
CPU Intel Core i7-10700K 3.8 GHz 8-Core Processor €353.99 @ Mindfactory
Motherboard ASRock Z490 Phantom Gaming 4 ATX LGA1200 Motherboard €130.88 @ Amazon Deutschland
  Prices include shipping, taxes, rebates, and discounts
  Total €484.87
  Generated by PCPartPicker 2020-11-13 08:21 CET+0100
Type Item Price
CPU AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor €429.00 @ Amazon Deutschland
Motherboard MSI B550-A PRO ATX AM4 Motherboard €106.90 @ Amazon Deutschland
  Total €535.90
  Generated by PCPartPicker 2020-11-13 08:22 CET+0100
note that with that z490 board you can not likely overclock much since it is crap. if you want to oc then:
Type Item Price
Motherboard MSI MPG Z490 GAMING PLUS ATX LGA1200 Motherboard €153.90 @ Amazon Deutschland
  Total €507.89
  Generated by PCPartPicker 2020-11-13 08:23 CET+0100
Conclusion: Wait for the price of 5600x to drop. if you get 10700k is cost similar to 5600x while consumign more power and having little worse performance. if you wait for the 5600x to drop aroudn 80€ you safe 50€ going for AMD than intel.
+ 5600x should be around 300€ and now that msi b550 A-pro is only little over 100€ at germany it is a steal when the price drops.
cheapest for 10700k
Type Item Price
  Total €484.87
Type Item Price
  Total €535.90
Type Item Price
  Total €507.89
so in 1 months prices might favour AMD more?
not in 1 month. it is not in stock that is why to price is 430€ instead of 300€. Check everyday if it is at stock.
so which amd chipets are compatible with ryzen 5 5600x without BIOS update? Which chipset adds which function?
Some ATM. Yo have to look fo motheboard with ryzen 5000 ready sticker.  Most b550 and x570 board do have it, but the store can have old stock which need a bios update. Yo ucan always ask the seller to bios update it for you. Also you can check local pc stores, they usually bios update them for you.
48 minutes ago, SavageNeo said:
cheapest for 10700k
Type Item Price
  Total €484.87
Type Item Price
  Total €535.90
Type Item Price
  Total €507.89
The Z490-A Pro is the same price as the Asrock, and can run even a 10900K with the power limits removed just fine.
https://de.pcpartpicker.com/product/KXpmP6/msi-z490-a-pro-atx-lga1200-motherboard-z490-a-pro
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
1. is the b550 the non oc AM4 motherboard? 2. Do you actually get an improvement with gaming when you oc an ryzen 5 5600x compared to stock? Also can i ask the manufacturer of a mobo if their specific board has ryzen 5xxx series support out of the box?
What? Only A320 and A520 are non oc.
Litle. Or use PBO.
Yes, but the retailers can have old stock, they sell the old stuff before the new updated boards.
Litle. Or use PBO.
i wouldnt want to risk getting a non compatible mobo bios
