Yeah, keep pushing. Your voltage can get up higher, so can your Temps.
Google Thermal Limits, and TDP Limits.
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/126791-should-i-keep-going/#findComment-1686234
Where are you getting your readings? 56c with that cooler at that voltage and clock is pretty low.
Realtemp and HWMonitor
i9-6930X @ 5.3GHz | ASUS Z1007-A | 64TB G.Skill Ripjaw XIV 2400GHz RAM | GTX 1080 Ti | Corsair 900R
Corsair CX2500 W | 15TB WD Green | Noctua NH-D24
https://linustechtips.com/topic/126791-should-i-keep-going/#findComment-1686251
Ugh I wish my chip was good at overclocking... after having it sit at 4.8Ghz borderline 4.9Ghz for a year and a half its seemed to have lost its overclocking stability. Highest I can push now its 4.78Ghz. Meh...
Keep going OP! No point in buying a K series if your not gonna push it to it's limits like a enthusiast!
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
https://linustechtips.com/topic/126791-should-i-keep-going/#findComment-1686274
are you sure youre stress testing and stability testing properly?
make sure youre using proper tests that push your cpu to over 100%
the intel extreme overclocking utility is the best
https://linustechtips.com/topic/126791-should-i-keep-going/#findComment-1686275
The thing is, there are two problems. Intel extreme tuning utility does not show my voltage or the amount of cores, which is weird. I was running it and saw the temps max out at 56, but what I didn't see was that the cpu was only at like 20% load. I then used OCCT and got temps around 70, which makes sense. I pushed it to 4.4GHz at 1.25V and after a couple minutes of testing with OCCT, it BSOD'd. I set it back to 4.3 at 1.225 and its stable for now.
https://linustechtips.com/topic/126791-should-i-keep-going/#findComment-1686296
Could it have crashed because of the possibility that OCCT was overvolting it too much? I know that Prime95 and other stress testers bump up the voltage when testing.
https://linustechtips.com/topic/126791-should-i-keep-going/#findComment-1686313
