I've been meaning to upgrade my cooling system for a while now (I'll update my rig in my prof in a minute, but it's not crazy high power- 3600x, 5600xt) and I've decided on the cpu cooler but I'm stuck on the case fans. My case is matx-size with room for 2x140 in front, 120 behind, and 2x120 on top. I'm planning to move my current 120mm stock fan to the back and get 2 new 140mm for the front. I'm not doing any overclocking right now, I just want it to not flare up in noise while I'm studying or running basic programs. I'm stuck between the Shadow Wings 2 and the NF-P14s, but I'd be willing to spend a little more on something like Silent Wings 3 if the value were there. My case has a closed front with mesh on the sides of the front panel and an open bottom. It's not particularly restrictive but nowhere hear open-air.
Any suggestions welcome!
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
https://linustechtips.com/topic/1266480-im-torn-between-fans/
Fans are fans. There isn't a whole lot of difference so by the cheapest ones that look good.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1266480-im-torn-between-fans/#findComment-14189613
arctic p12 and p14 are awesome and cheap. they go head to head with NH fans at a way cheap cost.
not true
https://linustechtips.com/topic/1266480-im-torn-between-fans/#findComment-14192497
1 hour ago, narrdarr said:
not true
Please do expand. I highly doubt the that performance difference between a silent wings 3 and a nf p14 are noticeable and/or will impact somebodies purchase more than how they look or cost.
AMD blackout rig
https://linustechtips.com/topic/1266480-im-torn-between-fans/#findComment-14192601
I don't know how big of a difference there is at the really high end, but between cheap random RGB case fans I picked up at Canada Computers and a NF P14 I put in my case the other day, there's a massive amount of difference. The cheap fans had a lot more noise coming from them, even at low RPMs - but they look good, and they're RGB, so picking your fans carefully is worth it.
AMD Ryzen 9 5900HS @ 4.6 GHz | RTX 3070M 8GB | 24GB DDR4-3200 CL20 | SK Hynix OEM NVMe 1TB WD SN750 2TB | Windows 11 | ASUS Zephyrus G15
Razer Mamba TE | NuPhy Halo75 (Night Breeze Linear switches) | Razer Blackshark V2 | Gigabyte G27Q | Acer VG24Y
AMD Ryzen 3 2200G @ 3.7 GHz | AMD Radeon Vega 8 | 48GB DDR4-2666 | ASUS B550M TUF GAMING PLUS | Ubuntu Server 22.04 LTS
Previous:
Intel i7-8750H @ 3.8 GHz RTX 2060M 6GB 32GB DDR4-2666 CL22 | Kingston OEM 512GB WD SN550 1TB | Windows 10 | ASUS Strix GL504V
Intel i7-4700HQ @ 3.4 GHz | GTX 860M 4GB | 16GB DDR3-1600 | Seagate OEM 2x1TB 7200RPM | Windows 10 | ASUS G750JM
AMD Ryzen 7 2700 @ 4.1 GHz | Sapphire Radeon HD 5670 1GB, Sapphire Radeon HD 5850 1GB | 24GB DDR4-2666 | ASUS B550M TUF GAMING PLUS | Ubuntu Server 20.04 LTS
AMD Ryzen 9 3900X @ 4.6 GHz | GTX 1080Ti 11GB | 48GB DDR4-3200 | ASUS B550M TUF GAMING PLUS | Ubuntu Server 22.04 LTS
https://linustechtips.com/topic/1266480-im-torn-between-fans/#findComment-14192856
