Long story short I optimised my drivers, and now the pc won’t load up properly and takes me through windows automatic repair which never works, so then get the choice of shut down or advanced options, so I chose reset but.... windows will not let me reset. I’m not able to put any password into my account to log in, any help is appreciated. :)
https://linustechtips.com/topic/1266017-i-need-help-with-my-pc/
What drivers did you "optimize"?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1266017-i-need-help-with-my-pc/#findComment-14186445
sounds like it might have been a hack
https://linustechtips.com/topic/1266017-i-need-help-with-my-pc/#findComment-14186446
Yikes, I don't even want to know what this actually did...
Just reinstall with a Windows USB.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1266017-i-need-help-with-my-pc/#findComment-14186502
14 minutes ago, JoeC450 said:
Thanks for the advice ;)
I'd also look into the rest of your drivers. There's a chance that you had something way behind that was playing well, but doesn't cooperate with the new Nvidia drivers.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1266017-i-need-help-with-my-pc/#findComment-14186546
Before you do something drastic, like reinstalling your OS, can you detail your steps precisely?
For instance:
1: Installed GeFore Experience
or
1: Opened already installed GeForce Experience which I have used before
2: Selected Update Driver
or
2: Selected Perform a Clean Install for new drivers
etc
3: Midway through install, computer froze so I reboot, then couldn’t get into Windows
4: Tried recovering Windows but recovery did not work.
etc
For example, if you messed  around with your BIOS at some point, Secure Boot can throw people. Deleting an OEM partition and trying to reinstall Windows won’t work. UEFI can be a hassle...
Just more info needed...
https://linustechtips.com/topic/1266017-i-need-help-with-my-pc/#findComment-14186674
