CPU for RX 6800 XT?
Solved by BTGbullseye,
4 hours ago, SupersonicSaint said:I have an ASUS ROG STRIX B550-F GAMING (WI-FI) motherboard and a water cooled Ryzen 5 3600x
Depending on how good S.A.M. is, you may get 10% performance boost on top of the 20% boost you'd get from the 5600X... Or you may not get any boost on top of the CPU upgrade. The CPU however would be a worthwhile upgrade if a 17-23% average framerate bump is worth the price to you.
