I want to enter modding and currently learning CAD.  parts will be 3d printed.
Making a Valorant themed PC setup.
This is for the mic. PC case done
- Headphones and camera - "pending"
Chose the Seiren Mini by razer because of the size. Acoustics with the foam cover is to be determined. may change it to a plastic cover with a hole.
**also, May redesign it in the near future for  Injection Molding compatibility. Perhaps even making a mold for it. who knows
"Imagination through CAD makes it closer to making it."      -I say
https://linustechtips.com/topic/1265402-pc-cad-modding/
Is this a question or a statement?
If it's a statement, and you plan on following up in the future with your progress, then this can be moved into Build Logs.
https://linustechtips.com/topic/1265402-pc-cad-modding/#findComment-14181475
5 hours ago, johnpaulample said:
statement, sorry new here.
cant find the proper location for this. most of my searches ends up in CAD PC specs.
How do i move it?
Only mods can. We have wizard powers, like this!
-Moved to Build Logs-
https://linustechtips.com/topic/1265402-pc-cad-modding/#findComment-14182499
