Budget (including currency): Low 2000s
Country: Unitied States
Games, programs or workloads that it will be used for: General Gaming, some 3d mondeling
Hi! I just redesigned my build, and some people were saying that my cooler was not enough for my CPU. I was wondering if that was the case. and if so what one should i use? Thanks! It is the Cooler Master MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler pared with an i9-9900k. If there is a better cooler let me know!
PCPartPicker Part List
Type Item Price
CPU Intel Core i9-9900K 3.6 GHz 8-Core Processor $399.99 @ B&H
CPU Cooler Cooler Master MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler $49.99 @ Newegg
Motherboard MSI Z390-A PRO ATX LGA1151 Motherboard $119.99 @ Amazon
Memory Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory $64.98 @ Amazon
Storage Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive $69.00 @ Amazon
Storage Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive $54.99 @ Newegg
Video Card Asus GeForce RTX 3070 8 GB STRIX GAMING Video Card
Case NZXT H510 ATX Mid Tower Case $69.98 @ Amazon
Power Supply Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply $154.99 @ Corsair
Monitor LG 27GL650F-B 27.0" 1920x1080 144 Hz Monitor $299.80 @ Amazon
Mouse Glorious PC Gaming Race MODEL O Wired Optical Mouse $77.81 @ Amazon
Headphones SteelSeries ARCTIS 7 2019 Edition 7.1 Channel Headset $125.00 @ Amazon
Webcam Razer Kiyo Webcam $99.99 @ Best Buy
Custom CORSAIR K70 RGB MK.2 RAPIDFIRE Low Profile - Backlit RGB LED - USB Passthrough & Media Controls - Fastest & Linear Low Profile - Cherry MX Speed $119.99 @ Corsair
Custom Large RGB Gaming Mouse Pad - Soft Non-Slip Rubber Base Led Mousepad, Thick Computer Keyboard Mice Mat for MacBook, PC, Laptop, Desk(31.5 x 11.8 x 0.15In) $18.98 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $1800.46
  Mail-in rebates -$10.00
  Total $1790.46
  Generated by PCPartPicker 2020-11-04 17:17 EST-0500
https://linustechtips.com/topic/1265221-my-cooler/
On a percentage out of 100
How much is going to be gaming and how much is going to be productivity
https://linustechtips.com/topic/1265221-my-cooler/#findComment-14180103
2 minutes ago, RocketNinja15 said:
How does that effect what i choose?
You're spending too much on stuff you don't need
At 1080p, you really don't need a 3070, or a 9900k - I don't believe you would need 32GB of memory either seeing that you won't be touching the productivity stuff super often.
You can easily get by with midrange parts and save a few bucks
https://linustechtips.com/topic/1265221-my-cooler/#findComment-14180136
1 minute ago, spartaman64 said:
unless you need it asap or need to have intel for some reason i would consider waiting for ryzen 5000
True, I will wait for the rysen 5000 series to see how that is compared. How about the the cooler though. for what my parts are, is enough?
https://linustechtips.com/topic/1265221-my-cooler/#findComment-14180205
its certainly enough but at that price point i would rather have an air cooler like a scythe fuma 2
https://linustechtips.com/topic/1265221-my-cooler/#findComment-14180217
Eh. I don't like AIO's, and think you'd be better off with an air cooler.
Regardless, you won't be getting this chip anyways, so it doesn't matter that much
https://linustechtips.com/topic/1265221-my-cooler/#findComment-14180218
1 minute ago, RocketNinja15 said:
Why Dont you like AIOs
They perform meh for the price most of them are at.
Plus they're louder than an air cooler, have potential to leak or lead to pump failure
https://linustechtips.com/topic/1265221-my-cooler/#findComment-14180226
as @spartaman64said, a fuma 2 is a great cooler
So is a DRP4 or D15
But it really will depend on the chip you get. If you get something like a 5800x, the stock cooler will do morethan enough
https://linustechtips.com/topic/1265221-my-cooler/#findComment-14180326
