Budget: 1100CAD
Country: canada
Games, programs or workloads that it will be used for: warzone csgo editing and uploading YouTube videos and make rainbow Six siege in the future
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have all the peripherals but will be upgrading after I get the PC
https://linustechtips.com/topic/1264708-budget-build-help/
1 minute ago, LRG PHANTOM said:
Budget: 1100CAD
Country: canada
what resolution you want to play at and whats the refresh rate?
https://linustechtips.com/topic/1264708-budget-build-help/#findComment-14175847
Ideally, if you can wait for the 3060 or RX 6600 gpus and ryzen 5000. This is 100 CAD over budget, however money can be saved in some places by getting a cheaper case, or a lesser motherboard, or less storage.
https://linustechtips.com/topic/1264708-budget-build-help/#findComment-14175876
I changed the mobo because I might need to use wifi from time to time and I changed the SSD to another one that has a little more space and changed out the ram for cheaper ram with the same speed being 3200 2x8 GB cl16 but for 72 instead of 89
https://linustechtips.com/topic/1264708-budget-build-help/#findComment-14176000
1 hour ago, Abdullah Bhutta said:
Its not possible with this budget
Hence why I said down the road because I currently have a monitor I can use but it only goes 1080p 60 I'm waiting on my accident fund to come in then I'll have a budget of 400 to 475 on the monitor
https://linustechtips.com/topic/1264708-budget-build-help/#findComment-14176222
I mean that you will have to get a Better Graphics Card in order to play at. 1440p@144hz
https://linustechtips.com/topic/1264708-budget-build-help/#findComment-14178254
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1264708-budget-build-help/#findComment-14178289
Heres a list I made. This mobo is suprisingly good, and it should have good enough temps. It should also be ok for 1440p144fps in esports titles.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1264708-budget-build-help/#findComment-14180472
