If its Windows 10 Pro just install the hyperv role
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1264280-vm-creation-help/#findComment-14172436
i'd recommend hyperv over virtualbox. vb is easier to use, but hyperv is more powerful and in my experience, ive had less issues with hyperv than virtualbox.
See: https://docs.microsoft.com/en-us/virtualization/hyper-v-on-windows/quick-start/enable-hyper-v
under 'Enable the Hyper-V role through Settings'
https://linustechtips.com/topic/1264280-vm-creation-help/#findComment-14173332
Depends what you wanna do with the Ubuntu server VM. If you just want to try things out with it. I would use personally Virtualbox or VMware workstation. Its easy to rollback, change or delete. But if want to really use it for something like a minecraft server or for hosting a website. Its better to do it in HyperV if it is a Windows 10 pro box. Because it's more stable just like @smokeweedeveryday said.
https://linustechtips.com/topic/1264280-vm-creation-help/#findComment-14176084
I have the home version but i managed to create one with oracke vm so ko problem
https://linustechtips.com/topic/1264280-vm-creation-help/#findComment-14176673
