Hey there,
I was thinking about buying and downloading titanfall on Pc.
Does anyone know the download size, I can't find any accurate posts.
Thanks
Intel i5-4670K, Asus Maximus VII (z97), 16gb Kingston, Asus Gtx 780, Fractal Design Define Mini, 250Gb Samsung Evo, Corsair CS650M
        Yey dis meh Pc
https://linustechtips.com/topic/126400-titanfall-download-help/
I've heard it's 50GB all in all, 35 of those are sound files from what I've seen. O.o
Wow I think ill just buy the Disc.
        Yey dis meh Pc
https://linustechtips.com/topic/126400-titanfall-download-help/#findComment-1681076
according to my origin download screen right now it is 49.99gb basically 50gb. apparently like the others have said a good portion is audio files and compatibility files for a large variety of systems. Physical copy is 3 discs and according to my co worker you still have to download some things after that
https://linustechtips.com/topic/126400-titanfall-download-help/#findComment-1681090
I don't think you have to download anything. When I installed it via DVDs, it took a couple minutes to unpack the audio files. The whole process took less than 10 minutes.
CPU Intel Core i7-4790K Motherboard ASUS Saberthooth Z97 Mark1 RAM Corsair Dominator Platinum 16GB @ 2133MHZ GPU 2 X MSI GeForce GTX GTX 980TI GAMING 6G SLI Case Phantex Enthoo Evolv ATX Storage Samsung 840 Pro Series 256GB / Western Digital Caviar Black 2TB PSU Corsair RM1000i Display Asus 4K PB287Q Cooling Noctua NF-A14 FLX & NF-F12 PWM /Thermaltake Water 3.0 Ultimate 360mm Keyboard Corsair K70 Mouse ROCCAT Kone XTD Sound Card Asus Xonar STX
https://linustechtips.com/topic/126400-titanfall-download-help/#findComment-1681108
The Origin/download/Installer only grabs 21GB for you,......and it unpacks to 50GB.
You do NOT download 50GB of data.
As it downloads it decompresses/unpacks, meaning you actually download about 21GB, and it unpacks to 50GB, 35Gb being audio.
Its really stupid that they did not have Origin do the 1-100% being 0-21GB and then unpack like it does.. making it say 50GB is misleading as your not downing 50GB but 21GB.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/126400-titanfall-download-help/#findComment-1681110
Thanks for the help guys.
Sorry for not responding......Had work
        Yey dis meh Pc
https://linustechtips.com/topic/126400-titanfall-download-help/#findComment-1681913
