hi guys
i have a strange problem with my other PC,
when windows starts the GPU fans start spinning at 100%, i tried using Gigabyte Aorus engine or MSI afterburner but i cant control the GPU fans, 0 effect on them
i unplugged the GPU and tried it on another PC and it works, there i can control the fans and the problem does not exist, so its not a GPU problem
when i uninstall NVIDIA driver the fans stop running but as soon as i install the driver again the problem is back
when i turn on the PC and go to BIOS it works normally
PC Specs :
CPU : i5 9400F || RAM : 16GB || GPU : RTX 2060Super
what can be the problem ?
Main PC :
CPU : i9 10900K || RAM : 64GB || GPU : RTX 3090
Workstation PC :
CPU : i5 10400F || RAM : 48GB || GPU : RTX 2060Super
SFX PC :
CPU : i5 9400F || RAM : 16GB || GPU : RTX 2080Super
https://linustechtips.com/topic/1263814-help-my-gpu-is-going-crazy/
12 hours ago, Ishnifan said:
could be a defective gpu but lets see the answers from others
This was my first thought but when I used the GPU on another computer to see if its a faulty GPU everything worked fine including the option to control the fans, so it's a bit weird
Main PC :
Workstation PC :
SFX PC :
check what the maximum vram capacity for your mobo is on the pc you have problems, could be that your mobo just cant handle 8gb vram, unless this is the first time you got a problem on the pc you use it in.
When you upgraded, did you DDU the old drivers or was this an all new build?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
This is a one year old bullid, the card was in there from day 1, its the first time such thing happening so thats a little bit odd
Main PC :
Workstation PC :
SFX PC :
