Hi,
I have a Corsair Carbide 678C case and Corsair Vengeance RGB Pro RAM. I've decided on the Noctua NH-D15 chromax black cpu cooler. Would that clear the RAM and still fit inside the case? Is this CPU cooler best for the AMD Ryzen 7 3800x 8-core 105W TDP processor? I'm not doing any overclocking but will be playing iRacing. Thanks for help.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/
Whether or not it will clear your RAM depends on your specific motherboard. Same when it comes to clearing the VRM heatsinks.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14160354
ok I have the Asus B550 F-Gaming Motherboard (Wi-Fi) is there a better CPU cooler that you recommend for what I have? preferably air cooled that would fit better.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14160411
“Better” is one of those very imprecise words. Better as in most powerful available period? It’s close.  It competes with a bunch of “big air” coolers.  The le grande macho RT for example is one that is as or more powerful.  It’s also cheaper. It’s got a worse rep about fitting on various motherboard and accommodating various types of ram though it is also shorter. Gelid also has a competitive cooler that I heard was going for drop-your-jaw cheap recently in Europe.  It has a rep for being annoying to fit.
there the Assasin3 and a couple others as well. Corsair has one that developed a rep for really bad cooling plate evenness.
“better” as in will cool my chip good and look nice and be easy and not cost a lot?  Not even close.  It’s only a 105w chip.  “Big air” coolers are usually more than 200w.  You could pick up some good four pipe cooler that can do, say 140w for $30 that would be fine.
Edited by Bombastinator
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14163829
I was considering the noctua nhd15s would that one clear Corsair vengeance rgb pro RAM?
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14165551
1 minute ago, woody30 said:
I have the Asus b550 f gaming with wifi motherboard atx.
I’m trying to remember where they start measuring this stuff from.  RAM usually has heights listed at least somewhere if not at the place you’re buying it from.  “Ram clearance” is also usually given for coolers. The fussy bit is the height of the bottom of the rams slot and the thickness of the cpu package the cooler sits on.  Cant be more than 5mm total.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14165708
Hi,
I have an Asus b550 f gaming motherboard(wifi) and amd ryzen 7 3800x 105 watt TDP processor, 8gb 2060 super and corsair vengeance rgb pro RAM. Considering the VRM heatsink and RAM clearance will the Noctua NH-D15 fit on my board and clear the RAM and VRM? Thanks for help i don't want to do any overclocking but just gaming on iRacing
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14166648
18 minutes ago, jaslion said:
You could just get a sycthe fuma 2. Smaller cooler almost same performance (1-2c of the noctua).
I have considered that one, but really like the customizable heatsink covers on the nh d15 chromax. Do you think the nh d15 will fit?
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14166733
The cooler is offset, dual or triple channel is not a problem, even with all dimms populated. Problems could come with quad channel setups that use certain sticks. I am running LGMRT with no fan right now, semi passive. Its great. I have never had a computer this quiet lol. All of my fans are turned down except the VRM. Ahh. Anywhoo, it can passively cool up to 90w, and for the first time I am taking advantage of it lol 😄
4400Mhz on my 3770K with Linpack Xtreme and no fan is about 80 load, at 4500 no fan is just under 90 load in a big R4. Awesome.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14167047
Ah. Noise.  That’s a trick.  You’ve got to run one with low speed fans.  Full passive in a bolt on cooler is out.  A nofan 95 is a hundred bucks, is the size of half a bowling ball, and will only really do a 3600x. Big air makes a lot more sense then.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14167081
The heatsink itself will fit but the front fan wouldn't. That being said, the cooler works fine with just a single center fan.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14167149
Noise is a trick. No need to run a fan on it, unless you want to push more than 90w. Best I could do is about 80w with my 3770K. You can run LGMRT full passive. I'm impressed.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14167529
4 hours ago, jaslion said:
Without the front fan sure.
To be perhaps unnecessarily specific the front fan will sit over the ram.  The fan can sit wherever it sits though.  If the ram is tall the fan will sit high.  Depending on ram height perhaps too high.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14167971
  Hide contents
Thank you so much for this reply, how are the Temps with just center fan?
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14168343
Short version:
very vaguely the same.  There will just be more noise (probably)
Long version:
That’s somewhat difficult to say in a specific case as there are so very many variables.  Very generally a second fan on a cooler does not double airflow.  It usually adds more like 20% but does not increase the actual cooling capacity much at all as it doesn’t change how big the cooler is.  It can lower total noise in specific circumstances, but in others it can actually make it louder.   The big noise advantage is when fan speeds are low but not quite low enough.  Fan noise curves are not flat. There tends to be a sharp drop off below a critical speed.  If you double the noise but increase airflow by 20% sometimes that total is lower.  Sometimes it is not. The cooler’s max capacity is WAY over the max heat output of your chip so fan speeds will be quite low while still achieving excellent cooling.  A similar cooling level could be achieved with a smaller cooler but would require more fan speed and therefore more noise.
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14168373
4 minutes ago, Bombastinator said:
Short version:
Long version:
  Hide contents
Ok thank yall so much for helping me on this
https://linustechtips.com/topic/1263586-air-cooling-pc-case/#findComment-14168385
