Hi, I'm having a problem with this guide I found online.
https://ubuntu.com/tutorials/install-and-configure-wordpress#4-configure-database
When I type.
mysql> GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,ALTER
    -> ON wordpress.*
    -> TO wordpress@localhost
    -> IDENTIFIED BY '<your-password>';
I get.
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-> ON wordpress.*
    -> IDENTIFIED BY '<your-pass' at line 2
The guide doesn't explain which password to use, or what these commands do.
I tries putting the commands in as-is, and various different passwords but I get the same error, the guide said not to bother wit an sql password so I didn't set that.
Any advice would be greatly appreciated.
Thanks
https://linustechtips.com/topic/1263542-following-guide-for-wordpress-stuck-on-sql/
    -> ON wordpress.*
Did the guide instruct you to make a MySQL account, using a "CREATE USER" statement? Did you include the "mysql>" and "->" in the command (if so, remove those).
Basically, what the command above does, is give a user (wordpress@localhost) permission to do certain action within the database (that's the SELECT, INSERT, etc.).
If possible, could you link me the guide (and if there are multiple steps, please tell where you are in the steps currently), maybe I can check some things to give the code above some more context for myself.
I'm at this step currently  https://ubuntu.com/tutorials/install-and-configure-wordpress#4-configure-database
Yeah, I put the -> in, oops.
I'll try the command without it.
The guide didn't tell me to create a user or set a password.
Tried the edited command.
ON wordpress.*
now I get.
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'IDENTIFIED BY '<your-password>'' at line 4
What password does it want, what should I put if I haven't set one?
Try this:
IDENTIFIED BY 'root';
Nah, same problem.
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'IDENTIFIED BY 'root'' at line 4
The good news is Apache is working, I can get to the default page.
I'm thinking of starting again, following a different guide, most of them use MariaDB.
Do you think it will cause any conflicts with mySQL, Should I uninstall it?
The sql statement you are trying to use is creating a new user and applying its privileges in one statement. After version 8 of mysql/mariab you can no longer do this.
You first have to create the user
CREATE USER 'wordpress'@'localhost' IDENTIFIED BY 'your password here';
Then apply its privileges
GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,ALTER ON wordpress.* TO 'wordpress'@'localhost';
