7 minutes ago, Caroline said:
Fan could be faulty, which power supply is it? there are a bunch of 750W TT PSUs, btw there's a subforum for this
It's the rgb 750w thermaltake 80 plus bronze in a couple of months I'm building a new Rig ik getting a RM850w from corsair power supply
So i was playing some fort i use all low settings when i take off my headset i hear a weird noise coming from the bottom of the case i was worried but my system is running good its just my power supply was making a weird noise i have a Thermaltake Smart BX1 RGB 80+ Bronze 750W SLI/Crossfire Haswell Ready Continuous Power ATX12V
2 minutes ago, Caroline said:
If it's rattling then the fan is either stuck or hitting a wire
@Spotty sorry for the ping, you're kind of the only mod I can remember now
The noise stoped when i moved the pc it was making like a hissing noise when playing i was also using my PC for a long period of time
Threads merged and moved to cases and power supplies
You can just report the post as "posted in the wrong subforum" and it'll get sorted. 👍
