Any cable management advice?
By
Zonal
in Build Logs
in Build Logs
Solved by Jumballi,
Take it apart and put it back together and then repeat 3 times, you'll see what needs to be optimized that way.
I find putting the cables in the motherboard first and then having them go to the power supply or drive helps as well.
Things I notice right away:
gpu power cable coming from bottom, have it come from the top to reduce sag
6
popularlion ·
Posted in Troubleshooting4 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking16 -
apoyusiken ·
Posted in PC Gaming9
