Depends.
If you're playing at settings reasonable for a card like this (e.g. 1440p maxed out), unlikely.
If you're playing at lower settings (e.g. 1080p, no RTX features, etc.), probably, but pretty much every CPU will do that. If that is your use case and you don't plan on upgrading your monitor, then I don't recommend getting this card.
https://linustechtips.com/topic/1262611-will-it-bottleneck/#findComment-14158029
4 hours ago, nox_ said:
Not in any significant way.
Depending on what you do with it.
Benchmarking etc then probably.
There will likely be no noticeable impact on the gaming experience.
Really depends on what the OP is worried about and what they want to do with the PC.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1262611-will-it-bottleneck/#findComment-14158538
4 hours ago, Krishdude said:
prolly about a 25% bottleneck at 1080p, 5-10% at 1440p, almost none at 4k in AAA games.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1262611-will-it-bottleneck/#findComment-14158556
