So I am doing a complete custom pc build, almost no expense spared.
I have stumbled upon a slight issue because I'm building my own ¨case¨ I forgot everything about the power button and front Io ports. Which is why I have come here to help, the motherboard I have chosen is the MSI MPG X570 GAMING PRO CARBON WIFI and I have absolutely no idea what to purchase as to use for the Io ports and power button.
So if anyone have any tips or tricks I would be very grateful for that, I will of course write below all the hardware that I will be purchasing for this build.
Motherboard: MSI MPG X570 GAMING PRO CARBON WIFI
CPU: Ryzen 9 3900x
GPU: MSI GeForce RTX 3080 Ventus 3X OC HDMI 3xDP 10GB
PSU: Corsair RM Series™ RM850 80 PLUS
RAM: ADATA XPG SPECTRIX RED D41 DDR4 2x16GB 3200Mhz (I will buy to of these so I have 64 GB of ram)
CPU Cooler:
Fans: Corsair LL Series LL120 RGB (Will buy 4 of these included a hub so I can control the rgb)
Thank you in advance for taking your time to help me :- )
Best Regards
Alex
https://linustechtips.com/topic/1261631-100-custom-build/
