Recently my generic PSU died and my family helped buying a new one since we don't really have money to be spending
I bought a Thermaltake Smart 500w and everything was okay till last night.
Last night the pc turned off as usual and I turned off the stabilizer as I normally do.
Today I turned the stabilizer back on just to see the gpu, keyboard and mouse lights turn on for a milisecond and the power button does nothing, like if the psu short-circuit protection triggered or something, what do I do? :(
https://linustechtips.com/topic/1261262-is-this-a-psu-problem/
Plug the PSU directly in to the wall. Turn the switch on the PSU off and on again.
Does it work?
https://linustechtips.com/topic/1261262-is-this-a-psu-problem/#findComment-14147053
18 minutes ago, spartaman64 said:
what are the rest of your specs?
i7-7700
Msi GTX 1050ti
Asrock H110M-HDS
x2 Ballistix Sport 2400mhz
480gb sandisk ssd
1tb seagate hdd
Generic keyboard
Razer basilisk
Does it work?
No, same thing, a milisecond of lights and then nothing
https://linustechtips.com/topic/1261262-is-this-a-psu-problem/#findComment-14147098
Giving an update:
I literally unplug everything, I disassembled the computer almost entirely, took the gpu out, the motherboard, switched the ram positions, didn't bother taking the psu out and re-sorting cables, same with the ssd and hdd, and then assembled it all back together and now it turned on properly.
I'm still worried wtf was that? Why did it do that? Is it going to happen again? Is something in my pc going to die? I'm like super stressed with this
https://linustechtips.com/topic/1261262-is-this-a-psu-problem/#findComment-14147290
8 hours ago, Racknoc said:
Giving an update:
More than likely something wasn't plugged in all the way.
I wouldn't worry about it.
BUT..
I would be thinking about getting a better quality PSU than what you have.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1261262-is-this-a-psu-problem/#findComment-14148136
BUT..
I would but I don't have money. My previous psu was a Sentey xcp 630 and lasted for some 4 years
https://linustechtips.com/topic/1261262-is-this-a-psu-problem/#findComment-14149150
