Best monitor for around 200 euros for productivity and work
boredatwork
I am building a PC for my sister, a workstation build. Because the budget is limited, i would like some recommendations around 200 euros for a productivity monitor. Thanks in advance!
There is this Philips 4K monitor
and you dont really have good ultrawides at this price points, but I think that the Philips monitor is one of the best value monitors on the market its a 10 bit (and native 10 bit not 8 bit +FRC) and its also 4K and its 27 inch
Displayspecifications is almost always right and they still list it as 8-bit + FRC
https://www.displayspecifications.com/en/model/f02b1537
Otherwise seems a good option, native 10-bit monitors cost a lot more usually.
I edit my posts more often than not
5 minutes ago, narrdarr said:
What kind of productive?
3D rendering and editing
thanks i will check it out
thanks i will check it out, but it does seem a bit expensive, especially in euros, when it goes up to the 300s range
4 minutes ago, Elad.Evron said:
the philips website says otherwise but its still a very good monitor
You mean:
https://www.usa.philips.com/c-p/276E8VJSB_27/4k-ultra-hd-lcd-monitor
Quote
Display colors
Color support 1.07 billion colors
Well, they are "optimistic" about their product specs.
Still a good monitor though.
1.07 billion colors is the amount of colors for 10 bit colors
but its still a good monitor
Also they added the words "Color support"
Trust me it's not native 10-bit
I trust you, but I know poeple with this monitor and I can tell you its a good monitor
