Would I be able to use Kalih Box Switches in this case & pcb?
Solved by Eschew,
26 minutes ago, MoozOfDoomz said:I'm very new to custom mechanical keyboards. From what I've seen I think I'm going to use Kalih Box White switches. Would those fit in this? I've only seen MX style switches put in it.
Hey there.
Yep. The GK61x/GK61xs PCB is compatible with both PCB-mounted (5-pin) and plate-mounted (3-pin) switches. Most, if not all, Kailh BOX switches are plate-mounted.
Pic of BOX Switch Pins:
