I'm building a pc for the first time I've spent about a week now researching good parts for the pc and I came up with a list
Ryzen 5800x cpu
Asus tuf rtx 3080 graphics card
Asus tuf x570 plus motherboard
4 x 8gb ram corsair vengeance rgp pro
Lian Li pc-011 dynamic razer case
So basically I think all the parts I have so far are compatible and work together great im not 100% sure if that case is going to be good. Also im stuck on what cooler to get and if I will need additional fans around the inside of the case to keep it cool as well as what positions to put them in. Then I can add all the watts together in order to select a good power supply for it all I am hoping to get my rig together before the 13th of November when the new cod drops assuming I'll be able to get my hands on a 3080 off the shelf of a store im willing to spend 3k for the build but if possible I'd like to stay under 2500 I just want to get a cooling system that will 100% keep my parts cool i don't want my money to go to waste 😖
https://linustechtips.com/topic/1258037-i-need-some-help-with-part-selection/
Honestly, this is a really good build, id recommend the h150i rgb pro xt or cappelix if you want more rgb that great airflow case and get lucky enough to get a 3080 and your all set for 1440p 240hz or even 4k 60hz
Ok so I like those options for the rgb fans but I'm unsure if they are compatible with ny cpu socket and I dont know how to find the type of socket I have on my motherboard pls help >.<
Thank you for sending me nice fan options I would prefer a air cooler instead of liquid but I like the rgb for the liquid ones ankh sent are you sure 750W is enough to power the cpu gpu fans etc?
Oh don't worry it will be enough, id recommend the rm750 from corsair
Wait you should buy the one with wifi and you need storage
out of the 4 zen 3 cpus the 5800x is the worst deal, other than that the build looks good
i recommend 4x8 ram over 2x16
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
