One 1440p/4K or Two 1080p. HELP!
HYDRYL
Specs: i5-8400, GTX 1050Ti, 16GB RAM
I want to buy a new monitor(s) but confused between these choices.
  • One 1440p IPS
  • One 4K VA panel
  • Two 1080p IPS dual monitors
All are almost at same price. Mostly multimedia work, MS office, movies etc. Sometimes casual gaming. Graphics don't matter to me in gaming.
Currently using 720p on 32" for 2 years and want to use a sharp monitor with space for atleast 2 windows on it. That's why I am confused on these.
I want the space and don't want pixelated text like I am using now. Please suggest what would suit best for me.
Note: Overall workflow is important, gaming is not a priority.
I use 3 Monitors on my Workstation. Depending on the Tools you use, its way better than 1 Screen.
I would choose 2 if work is the main use.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
go 4k then , I've been on 4k for 4 years and never went back.
Especially for multimedia work as your monitor should be higher res than what your working on so you can actually see what youre doing
Get a 32" 1440p monitor. Use the old one as a second screen.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
People say that if you watch 1080p movie on 4K screen, it looks bad compared to 1080p screen as it upscales the content. Is there a noticeable difference?
24 minutes ago, Slyceth said:
Have you considered getting an Ultrawide?
Only 2560x1080 is available here. Its doubtful that I'll like the 21:9 ratio. I need vertical pixels as well.
it depends on the method it uses , but on both my tv and pc monitor neither seems effected.
I use my 4k setup for film stock restoration so I tend to watch a lot of oddball resolution video and it seems fine to me.
I will say , running my previous 4k tv at 1080 as the resolution produced a terrible picture , but running it at 4k then just expanding the video to fit the 4k resolution worked fine.
