Monitors for RTX 3080
DHV0
I'm currently looking at the LG 27GL83A-B 27 Inch Ultragear QHD IPS, would this be a good choice?
I'm also looking for recommendations too, thank you!!
Link to LG 27GL83A-B
CASE: NZXT H510 ELITE MOTHERBOARD: ASUS ROG Strix B550-F Gaming (WIFI 6) CPU: AMD Ryzen 5 5600X 4.7GHz (ZEN 3COOLING: Arctic Freezer II AIO 280mm RAM: 32GB Corsair Vengeance RGB PRO 3200MHz CL15 GPU: NVIDIA RTX 3080 Founder's Edition PSU: Thermaltake RGB 850w 80+ Gold STORAGE: SSD Samsung 860 EVO 250GB // M.2 NVME WD BLACK 1TB // M.2 NVME Samsung 970 EVO 1TB // HDD Seagate 2TB OS: Windows 10 Home x64 Bit MONITORS: LG 27GN850-B @144Hz 1440p // Acer XF270H @144Hz 1080p MOUSE: Razer Viper Ultimate Mercury White KEYBOARD: Razer Huntsman TKL (w/ Razer Mercury White Keycaps) HEADSET: HyperX Cloud Flight
1440p is more in line with a 3070 imo. A 3080 makes more sense at higher resolutions. Not a bad combo tho, just pointing that out.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
4K 144Hz isn't for 3080 yet either. At least in many newer graphically heavy games, maybe in lowered settings though.
What I mean is -  it's perfect for 1440p for any game.
I edit my posts more often than not
I think a 1440p 170hz or 240hz would be the sweet spot, but i dont know; the lg is pretty appealing
Yeah, Nano IPS is supposedly great.
By the way LG 27GL83A-B and LG 27GL850-B are basically identical.
Another model I'd consider at 1440p is - Dell Gaming S2721DGF
But thats not Nano IPS
I agree, 3080 can’t do “high refresh gaming” at 4k. But, a 3080 will be getting very very high FPS at 1440p... a 3070 will be plenty fast enough to push 140-150+ FPS at 1440p, that’s all my point is. Saving 2-300 bucks to get effectively the same performance seeing as the monitor is only 144hz, not a bad bargain. Depending on build budget as it looks like OP is looking for a zen 3 upgrade, if 1440p is the goal, OP can use that money for the cpu/mobo/ram combo OP is looking for. If there is 0 budget constraint, sure, why not.
I haven't got my 3080 yet but I am running a 27gn950 (4k 144hz). my 2080ti does 4k fine (I mostly play FPS i get 100fps in modern warfare medium/high settings and 350fps in overwatch low settings). I feel like most of the games that are "graphically demanding" most people bring up in the 4k vs 1440p argument (control, horizon, tomb raider ETC) are games that are going to benefit more from graphical fidelity than FPS in the 120-240 range, especially since these are typically non competitive AAA titles that are made to be playable on console level FPS. given the implementation of DLSS 2.0 i think there is going to be a 4k 144hz renaissance
i9 10850k @5.1ghz  |   evga XC 2080ti   |  Asrock z490 Taichi  |  4x8gb g.skills trident z 3600mh  |  2tb Samsung 970 pro m.2 NVME  |   Lian li PC-011D  |  |  lian li Galahad 360 AIO  |    LG 27gn950 144hz 4k  |  Logitech G915 wireless/Logitech G pro Wireless/ Logitech G Pro X wireless headset
