Hello just looking for some good premiumish wired earbuds any suggestions? Been looking for a little while now want something premium around 50gbp ish.
Been using the akg earbuds that come with the samsung galaxy s10 don't want these again.
Don't want wireless or bluetooth, would like something with a 3.5mm jack.
Also would like to be comfortable to wear.
Did start to look at the senheiser ie4's but would  prefer something a little more pricer no more then 90gbp preferably (great British pound) everything seems to be wireless or Bluetooth did look through the linustechtips audio playlist but best video is only about wireless earbuds.
Never tried in ear monitors so may be open for suggestions, however would like something that doesn't need a dac or amp whatsoever.
Give as many suggestions as you like.
Cheers.
https://linustechtips.com/topic/1256750-wired-earbuds/
Cheers.
Beyerdynamic Soul BYRD
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1256750-wired-earbuds/#findComment-14108928
I'll recommend KZ ZS10 Pro just because I love KZ (no other reason, honestly) but @rice guru is probably the best person ask this question to.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1256750-wired-earbuds/#findComment-14114975
Cheers.
What kind of music do you listen to?
https://linustechtips.com/topic/1256750-wired-earbuds/#findComment-14115120
8 hours ago, bobman279 said:
Have you used these?
I've tried them once from a friend and the quality is pretty high and the audio is pretty neutral.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1256750-wired-earbuds/#findComment-14115743
are a bit over priced for a pair of IEMS with quationable durabilty due to the mildly low quality attached cable.
https://linustechtips.com/topic/1256750-wired-earbuds/#findComment-14117283
This is a pretty easy one! Tin T2s! Well known at this point for their extraordinarily good sound performance and features at a low price. Detachable cables specifically are a huge plus because if your cables get damaged you just buy some new ones and keep jamming! They're very neutral, and detailed and also quite lightweight.
Amazon UK (£44.99)
Zeos Review
DMS Review
Steve Guttenberg Review (I don't personally care for the guy, but even he is impressed!)
The previously mentioned KZ ZS10 Pro are a great option as well. Although have a worse stock cable, don't include foam tips and are a bit bulkier if it matters to you. As for sound they have better bass than the T2s with a bit less soundstage but more detailed overall. Really down to preference and/or availability, you'd be happy with either choice.
Amazon UK (£39.99)
Zeos Review
- Personal Rig -
AMD 7950X3D / 64GB G.SKILL DDR5-6000 EXPO / ASUS RTX 4090 TUF OC
ASUS ProArt X670E / Noctua NH-D15 Corsair 4000D Airflow / Corsair RM1000x / 4 x 2TB Crucial P5 Plus
- 🪦 HW Graveyard 🪦-
MSI GTX 780 Lightning 3GB 🪦🫡 Dec 2013 - Dec 2018
Seasonic Platinum 1000W 🪦🫡 Dec 2013 - Dec 2018
PNY GTX 470 1280MB 🪦🫡 June 2010 - August 2017
Intel Q9550 / Q9450 Systems 🪦🫡 Q1-2008 - Q3-2016
- Desktop Audio Equipment -
ADAM Audio F7's | Topping D30 Pro | Topping A30 Pro | HD598 & HD6XX w/ Sheepskin Pads
https://linustechtips.com/topic/1256750-wired-earbuds/#findComment-14117699
