Audio interface line In won't work
Solved by Spork829,
On 10/11/2020 at 5:46 AM, The Flying Sloth said:Line-in probably refers to your motherboard line in so it makes sense your mic wouldn't come through that, if your interface isn't showing up in inputs I'm not too sure what's going on. Software has never really been my area of expertise though so perhaps someone else has some more specific info...
Got if figured out, turns out I had to match the sample rate in the Windows sound settings for the input device to that of the interface.
