If I were to plug in an old USB 2.0 A Male to A Female extension lead into a USB 3.2 Gen 2 (10Gbps) port on my motherboard, does the cable have the ability to downgrade the data transfer rate or shouldn't it matter?
i.e. Do i need to buy a USB 3.2 Gen 2 Extension?
Cheers,
Rhys
AMD Ryzen 7 9800X3D ASUS ROG Strix B650E-F RTX 5080 Founders Edition  Corsair 32GB 6000MHz CL30 Corsair RM1000x Fractal Design North
https://linustechtips.com/topic/1256158-do-usb-cables-limit-speed/
Yes they do and it's backward compatible.
So anything that has the same usb port can use it.
1 hour ago, Grumpy Old Man said:
The length of the cable does not affect the speed as much as the power delivery. Data travels at the same speed even if the cable wraps around the house a couple of times or just around the table, but a longer cable “wastes” power and the hard drive doesn’t necessarily work without extra power. You will notice a slowdown in data or on really long distances, e.g. around the globe in couple times or earth to sun.
Not really. 5 meters is the recommended maximum length of a USB 2.0 cable. If you're running a 10-15m cable you're not going to have nearly enough power without connecting powered hubs between 2 cables.
edit: Oh wait I read that wrong. Nevermind
Ada is worse than Ampere which is worse than Fermi, change my mind.
System:
  • CPU
    AMD Ryzen 9 5950x
  • Motherboard
    ASUS X570 TUF
  • RAM
    2X16GB Kingston Fury 3200mhz
  • GPU
    Gigabyte RTX 4080 Super Gaming OC
  • Case
    Fractal Torrent
  • Storage
    A lot of SSDs
  • PSU
    Seasonic 1000W Platinum
  • Display(s)
    Main: ASUS PG27AQDM 240hz 1440p WOLED
    Secondary: Alienware AW2521HF 1080p 240hz
    Third: Samsung C34F791 UltraWide 1440p 100hz
    Fourth: LG 48' C2 OLED TV
  • Cooling
    Noctua NH-D15
  • Keyboard
    Ducky Shine 7
  • Mouse
    GPX Superlight
  • Sound
    Logitech Z906 / Sennheiser 560s / Rode NT-USB
  • Operating System
    Windows 11 Pro
