use onboard audio to control monitor speakers
Ryzenuser19
is there anyway i can use onboard audio to control my monitors speakers, my onboard audio is pretty great for a cheap board. and the speakers in my monitor are pretty great. but i want to use them with my onboard audio. and there is no sound in for my monitor sadly...
specs in spoiler.
Motherboard
Asrock A320M
CPU
Ryzen 5 2600X
GPU/s
2x MSI RX580 Gaming X 8GB
RAM
channel 1 Corsair Vengence LPX  DDR4 2133MHz 2x4GB
channel 2 Kingston HyperX Predator DDR4 3000MHz 2x4GB
Cooler
AMD Wraith Max RGB Cooler
Case
CiT Seven
Storage Internal Only.
SSD  Crucial BX500 120GB
HDD Segate ST2000L 2TB
Monitor/s
LG UltraWide 25UM58
Acer XZ350CU 35" 21:9 Ultrawide
LG UltraWide 25UM58
Mouse
Logitech 203 Prodigy Wired
Keyboard
Logitech 213 Prodigy Wired
Your monitor use HDMI to stream the audio, if it doesn't have an audio input, there's no way you can use the onboard audio.
yeah i realised this and ended up using a mini 8ohm desk amp to power them and plug into the onboard audio i kept the original conector for the monitor so that i can solder a jack to the thing and put in my own audio in port. my monitor is a xz39cu so it never had a warrenty to begin with.
specs in spoiler.
Motherboard
Asrock A320M
CPU
Ryzen 5 2600X
GPU/s
RAM
Cooler
Case
CiT Seven
Monitor/s
LG UltraWide 25UM58
LG UltraWide 25UM58
Mouse
Keyboard
