I have an half dead USB stick, and am wondering if i can revive it somehow, I have already gotten all data from the folder i was trying to open, its very odd, sometimes it might open a folder, sometimes the explorer will not respond and I have to unplug the USB. If there is no way to revive it, it's ok, because there isn't a lot of important data on it.
https://linustechtips.com/topic/1255211-partly-corrupted-usb-stick/
Kingston usually has Lifetime Warranties on their USB drives. But with how cheap it is, it's probably not going through the hassle. Plus you're probably going to have to send the drive back to them without doing a secure erase of the data that's on it. Not sure how their RMA process and if they would allow that prior.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I didn't buy the drive directly from Kingston, so it doesn't have the Lifetime warranty, and the drive is quite old too and i recently bought a new drive
1 hour ago, Electronics Wizardy said:
You can try to use something like ddrescue on linux to get a full image of the drive. It seems like a hardware issue, and usb sticks are cheap, so id just toss the drive.
I've already bought an new drive, and im just rescuing everything i can with windows. And i probs wont be able to connect the usb to an linux vm, because it's so corrupt. And it probs wouldn't be worth the effort to rescue this drive.
Of you bought it second hand? It doesn't have to be directly from them, it could be through a retailer as long as you have the original receipt/ proof of purchase.
I bought it from an Latvian retailer, but it said that it has 2yr warranty, and I bought it like 4yrs ago
can you boot from a linux live disk and try dd rescue from there?
