Just csgo? What are the temps when playing?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1254898-0-fps/#findComment-14092195
either the game install or windows is totally messed up, or some busted ass hardware.
if you are only having problems in this one game, then the game is at fault
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1254898-0-fps/#findComment-14092201
Just now, wassup said:
i dont have an app to check the temps, and I only checked csgo so far
download hwinfo64, and try another game.
Bios database
prior build:
https://linustechtips.com/topic/1254898-0-fps/#findComment-14092204
Okay... I tested with other games and the same shit happens. Temperatures seem to go up a bit, but the real issue is CPU and GPU usage, which got up to 100% instantly. Next time someone tell me to buy a PC instad of a console im smakin them, this shit too much trouble
https://linustechtips.com/topic/1254898-0-fps/#findComment-14092264
its b/c you got a really old pc, lol. What are the temps? What res are you playing at?
Bios database
prior build:
https://linustechtips.com/topic/1254898-0-fps/#findComment-14092285
9 minutes ago, NineEyeRon said:
I played CSGO on an i7 920 and R380 with no issues, I am sure OP's PC is newer than that.
lol, if hes trying to do 1440p tho, though I cant help, since hes not replying. I played on a q6600 and a hd3650. THough, if hes going to go bac to console b/c he wont let someone else help him find outs waht's wrong, i don't know what to do.
Bios database
prior build:
https://linustechtips.com/topic/1254898-0-fps/#findComment-14092509
Bru yall are still on specs and resolution, that isnt it. I play this game for 5 years on the same pc. There is a bigger problem here with all of my games. not 1440p or any crap. Never changed my settings. If you want to know, my pc is the same as yesterday
https://linustechtips.com/topic/1254898-0-fps/#findComment-14092632
Your Hardware Specs are 100% not the Problem. And 100% GPU usage is what you want anyway. And i5..i5 what? And what Temp is "up a bit"?
How many Backdoors and Trojans are lurking around?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1254898-0-fps/#findComment-14094645
Core i5 4590. Im not aware of any trojans or backdoors. I tried running Malwarebytes yesterday, but nothing came up. I have two hds, but idk if malware bytes checks them both. The temp went from like 40 to 65 pretty quick, but that is not that high. The fans are working. Browsing works fine though. I think malware could be it, but idk how to check, because as I said, it was clear
https://linustechtips.com/topic/1254898-0-fps/#findComment-14095079
Install "Spybot S&D" and run a full system check
https://linustechtips.com/topic/1254898-0-fps/#findComment-14095154
Sorry I'm taking long to answer, ive had things to do. i ran this app and it detected some stuff nothing that seemed too terrible. When I clicked to fix it, the program crashed. I tried to test CSGO, and the frames were still dropping like crazy, but only every like 20 seconds. Its still unplayable, but its not frozen the entire time. I also got a message saying "Failed to open vpk file" and then just pointed out the files location
https://linustechtips.com/topic/1254898-0-fps/#findComment-14095523
Just run it again. It should have fixed the Issues, the crash aside.
And reinstall all your multimedia drivers. GPU, Soundcard ect.
Use DDU for the GPU Driver. And just run it. You dont have to go in safe mode.
https://linustechtips.com/topic/1254898-0-fps/#findComment-14095909
in my experience DDU not in safe mode never fixed anything, in safe mode tho yes. Also it's better to do it twice for some reason doesn't seem to catch everything in the first run sometimes.
Also the developer ( Wagnardsoft) highly recommends safe mode for this program,and he should probably know best!
-Scott Manley, 2021
https://linustechtips.com/topic/1254898-0-fps/#findComment-14098435
