Hey gang, I need to find a rare animal.
I'm looking for a backlit keyboard/mousepad combo.
I found the K830 from Logitech but it's a tad expensive. Any other suggestions?
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
https://linustechtips.com/topic/1254891-backlit-wireless-keyboardmousepad-combo/
It's not called a mousepad, it's called a trackpad or touchpad. You may be able to find more results if you search it with that instead. I've never used such a keyboard before so I don't have anything I can recommend. However it looks like the majority are non backlit and the few that are, are around the same price as the K830.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
No promises on build quality, but if you just need something that functions (hopefully) then this fits your criteria for way less than the K830:
https://www.amazon.ca/Rii-Backlight-Multi-Touch-Rechargeable-Raspberry/dp/B07TTS9Y8Q/ref=sr_1_1?dchild=1&keywords=rii+k18&qid=1602019065&sr=8-1
The searching I've done thus far doesn't seem to be bringing up any other backlit options within your budget though.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
That's exactly what i'm looking for, thanks!
No problem. Glad I could help!
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
