Hello every one, I recently bought a 2060 super for my pc. But after installing it I had no sound comming from my headset or speaker, only from my monitor. I tried a lot of things to get the sound working again, but I still hevent made improvement. I only hear a loud beep when I plug my headphone in, and that´s just really irritating. Does someone know what to do, it would really help my out.
https://linustechtips.com/topic/1254863-pls-help/
You need to have the sound not output through HDMI cable (my guess to why you are only getting monitor speaker sounds):
Control Panel
Sound
Playback tab
Make sure default isn't the monitors output device.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1254863-pls-help/#findComment-14091847
Have you forgotten to change the sound device? Click the speaker icon in the right corner and press the arrow and select your headphones?
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1254863-pls-help/#findComment-14091848
Control Panel
Sound
Playback tab
It still doesn´t work, I´m getting really sad now because I just paid 1300 euro´s for my first self build pc. But thanks for trying
https://linustechtips.com/topic/1254863-pls-help/#findComment-14091862
The reasons people dread building PC's even with all the information available on how to, is the minor issues - that still occur for System Builders - take a deep breath, its just 1s and 0s - the hardware either works, or it doesn't.  The software works, or it doesn't.  Continue to describe the issue, give us some screenshots as @Bad5ector requested etc
Hell I put in a new monitor last night and took me 5 minutes to remember just why it was polling at 60hz and not 144hz (a setting that I had to change embedded into Windows was the fix - for a few minutes I was like...da fuk?)
https://linustechtips.com/topic/1254863-pls-help/#findComment-14091915
Try to remove the GPU?
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1254863-pls-help/#findComment-14092150
Not that this fixes it the conventional way, but your monitor has a headphone jack, plug there and voila I hope?
https://linustechtips.com/topic/1254863-pls-help/#findComment-14092261
Have you tried this?:
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
https://linustechtips.com/topic/1254863-pls-help/#findComment-14092442
This works, thanks. But I will keep trying to make it work on the pc itself to
TBH the way you are describing this - is that you have sound porting through HDMI.  And you need to change that setting.  What motherboard?
https://linustechtips.com/topic/1254863-pls-help/#findComment-14094485
4 minutes ago, adriaan said:
MSI B450-A pro max
Looking at your screenshots again you need to DISABLE sound on your VG27A (monitor) so that it defaults to the speakers perhaps.
20 hours ago, adriaan said:
And what is the Steam Streaming Microphone - its acting as sound output device?
https://linustechtips.com/topic/1254863-pls-help/#findComment-14094585
i don't know why that Steam Mircrophone is there
https://linustechtips.com/topic/1254863-pls-help/#findComment-14094590
Disable it, and the monitor, does headphones from Mobo work now?
https://linustechtips.com/topic/1254863-pls-help/#findComment-14094595
