Budget (including currency): 1800~ AUD
Country: Australia
PC Usages: Need 240fps min in Overwatch, desktop virtualization and potential streaming.
Other details:
I currently have a very old pc.
i7-3770
16gb ram
random mobo/psu
350D
Will be needing new everything except graphics card right now, I have a 1080.
Prefer Air flow case and I would like to get a noctua cpu cooler.
https://linustechtips.com/topic/1254575-help-with-build-for-various-things/
do you need the monitor? Peripherals?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Bios database
prior build:
I don't think the GTX 1080 is not going to be enough to push Overwatch above 240fps at 1080p unless you set all settings to low(may be able to tweak some higher but for the most part they will need to be low).
Depending on how many desktop virtualizations you plan to run you may need more RAM but assuming you won't because then you would also need a CPU that is beyond the means of your budget.
PCPartPicker Part List
CPU: AMD Ryzen 7 3800X 3.9 GHz 8-Core Processor  ($549.00 @ PC Byte)
Motherboard: MSI MPG X570 GAMING PRO CARBON WIFI ATX AM4 Motherboard  ($420.20 @ Newegg Australia)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($211.00 @ Skycomp Technology)
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 NVME Solid State Drive  ($224.98 @ Amazon Australia)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($88.00 @ Mwave Australia)
Case: NZXT H510 ATX Mid Tower Case  ($112.20 @ Newegg Australia)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($188.00 @ Device Deal)
Total: $1793.38
Generated by PCPartPicker 2020-10-06 09:35 AEDT+1100
Total: $1793.38
This seems good but I only need a NVME ssd no other storage just yet, motherboard seems a little expensive.
Would a 10700k be better at this cpu price point? I think it's a 20aud difference and motherboard would probably be cheaper for a 10700k?
Maybe I could edge out a 3900x? If the motherboard is cheaper and no 3.5" hdd.
19 minutes ago, RAM555789 said:
He said he doesn't need a GPU and has a 1080, and if he is doing desktop virtualization, he will want a better CPU.
lol, oops.
Bios database
prior build:
Yeah take out the 3.5 and add a cooling solution of your choice and with a cheaper but still realiable (since I'm assuming you want wi-fi and overclocking) you could get the 3900X. It's a little hard to understand your pricing since it looks pretty weird to me as an American. They just kind of feel all over the place and don't translate real well in my brain.
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($210.45 @ Amazon Australia)
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 NVME Solid State Drive  ($224.97 @ Amazon Australia)
Total: $1704.82
Generated by PCPartPicker 2020-10-07 10:51 AEDT+1100
