Alright, so I made the mistake of setting some devices to a subnet mask of 255.255.255.254
What windows IP settings do I need to employ to actually be able to reach the webportal of the devices to reconfigure their network settings?
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/
i mean it depends on the ip's that you own/pay for.
as a device with that subnet mask only has space for itself on the subent.
don't you have physical access to the devices
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070262
Yes, I have physical access to the devices
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070268
Actually, a /31 mask allows for point to point connectivity so one host would be .0 and the other .1 if you do 192.168.0.0/31 as an example. OP would need to connect directly to the device and configure the other available IP in that subnet on their device to access it to fix this.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070274
if you can access the device and plug in a keyboard/mouse, just edit the subnet to a 255.255.255.0 this would put them in the same subnet as all other devices which ip starts with (ip used is purely random and to make an example) 192.168.0.XXX
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070279
oh, i must be remembering incorrectly.
but wouldn't a /31 allow one host since the two others would be occupied for the network/broadcast adresses
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070288
Devices configured with the /31 mask do not have keyboard/mouse capability. Can only factory reset or "log in" through a web portal to change settings.
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070293
A /31 is actually 2 addresses and is just a "broadcast" and "network" address but instead of leaving them "idle" in a sense you use both of those for each end of the link. It's used a lot in enterprise settings to conserve address space so you're not burning 4 addresses with a /30 but just 2 with a /31 since in most cases you don't need the other two :)
Prior Build Log/PC:
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070294
You would have to reset them to factory defaults or plug in a laptop or something, set the other side to the other address in the subet of /31 and then access it via browser on your device.
Prior Build Log/PC:
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070299
For typical subnetting, yes.
However, for a point to point link, the broadcast address doesn't really apply as there's only one address for it to "broadcast" to.
This video explains to pretty well:
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070300
oh, will remember that as i'm going back to school in a few weeks :)
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070301
Ok, so I'm connected with a laptop... what's the "other address" I should be using for the laptop? 10.60.13.104 is the device, for example
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070304
Yah, it was something I didn't see in school either, they stopped at /30s for subnetting and then /32 for host and a lot of older devices would actually warn you if you configured a /31 subnet because it wasn't as common 5-10 years ago.
Prior Build Log/PC:
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070307
In that case it would be 10.60.13.105
I would use this to make it easy and just set the mask to /31 and put in the device IP and calculate what you need to set your laptop/PC to:
https://www.calculator.net/ip-subnet-calculator.html
Prior Build Log/PC:
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070310
Well, crap. +1 is what I have been trying to use for the past half hour. Guess I'll bite the bullet and get those resets rolling.
Thanks dudes.
https://linustechtips.com/topic/1252421-subnet-newb-needs-help/#findComment-14070315
