How to Progress from Being a Beginner
Solved by Flojer0,
For me the most import thing has always been to find something I like working on and running with that for as long as possible. If unity does that then go for it. That would actually be a good step because you can stick with event driven programming for a little longer and get use to a different environment. Beyond that any of the languages Unity supports will let you do whatever you want. But if you want to learn something you can carry beyond unity then C# is where you want to go since none of the others follow standards.
