my friend has a 3950x cooled via a x-62 nzxt liquid cooler and his idle temp is 50 but under full load its 70-75. he thinks these temps are a bit high but who am i to know so please if someone knows if these are good temps or not. NOTE: his cooler is installed upside down (by mistake) so the nzxt logo is like upside down could that be a possible issue?
https://linustechtips.com/topic/1251517-3950x-high-temps/
Load and idle temps are fine, nothing wrong with them, and idle temps don't really matter, load temps do and they're decent.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1251517-3950x-high-temps/#findComment-14061792
when i get 75-84 degrees under full load? dude i gotta get this cooler!
lol where does he live? Egypt with you? I think the climate there is pretty hot so these temps should be really good
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1251517-3950x-high-temps/#findComment-14061796
he is an ac unit that keeps things cool in his room
https://linustechtips.com/topic/1251517-3950x-high-temps/#findComment-14061803
these temps are still good.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1251517-3950x-high-temps/#findComment-14061807
the block that mounts to the mobo can be rotated any which way, doesn't matter for performance.
Having the rad mounted to the top of the case, or to the front with the tubes at the bottom of the rad is best for performance and longevity of the cooler
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1251517-3950x-high-temps/#findComment-14061829
