help choosing a cooler
Go to solution Solved by LogicalDrm,
T200 is better of the two. It looks like it could be new edition of what TX3 Evo was.
Hi, im building my first pc and Im getting a corei5 10600k, I live in peru so I dont have a lot of options when it comes to parts, honestly speaking the only two real options i have are the coolermaster hyper t200 and the hyper t20, everything else is too expensive atm or is not for sale (i do plan on possibly improving that eventually) I wont be doing any overclocking to the cpu but i would like to do some light gaming with the integrated gpu, which one would you suggest i buy?
https://linustechtips.com/topic/1251167-help-choosing-a-cooler/
Both coolers would be fine for that CPU running stock. Though I'm not sure what sort of gaming performance can be had using the integrated graphics, I'd imagine not that great frankly. You won't be running any AAA titles and anything else you can run on it would have to be at low details and low resolution.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1251167-help-choosing-a-cooler/#findComment-14058693
ill mostly be playing wow classic and warcraft 3, maybe some dota in low settings, nothing too fancy.
visual novels are awesome too and you dont need too much processing power for those.
https://linustechtips.com/topic/1251167-help-choosing-a-cooler/#findComment-14058772
