motherboard Need some help about motherboard
Solved by sarabjeet24,
19 minutes ago, Conza said:Well, looks like it maybe can overclock? This is the closest thing they have to a manual
https://www.galax.com/downloads/AMD BIOS chart V1.0.pdf
From a brief Google, looks like "A320 chipset supports RAM overclocking".
I reckon go with 3000mhz, see if it's stable, then see how far you can go if you're willing to go further.
Thx for reply but my ram timings is 16-18-18-36 but 3000mhz is only available for 16-18-18-38
