Should I go with 2 140mm fans or 3 120mm?
Solved by Hairless Monkey Boy,
3x 120s will likely push more air at the same noise level, or the same air at a lower noise level vs 2x 140s. They will also likely have a higher max airflow. I prefer 140mm fans in general, but in this case I'd go with 120s.
Featured Topics
mrtwonavels ·
Scitesh ·
Posted in Troubleshooting0 -
OllyOllyOxycontin ·
Posted in Troubleshooting1 -
4
4
ImTehCookie ·
Posted in Networking0 -
Worstcaster ·
Posted in New Builds and Planning1 -
