I think every one knows about how  ryzen 3rd gen cpu loves faster memory speed .
I am using the ryzen 3 3100 and I am on tight budget. I am going with 16 gigs of ram @ 3200 mhz . But is it that different from 3000 mhz ? I can save some money on upgrading any thing else if it isn't that different. I need to know how much will that affect the fps and if it is worth paying extra bucks for just 200 mhz ?
https://linustechtips.com/topic/1250235-is-it-that-difference/
and what are the timings for both?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1250235-is-it-that-difference/#findComment-14049748
1 minute ago, the cool guy X_X said:
Both cl16
how much are they? or how much price difference?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1250235-is-it-that-difference/#findComment-14049753
Both cl16
then yea the different wont be huge, if you can't afford the 3200, you wont be missing out on a lot.
though if possible, go for the 3200 cl16 kit.
Build Log:
https://linustechtips.com/topic/1250235-is-it-that-difference/#findComment-14049755
I wonder how hard it would be to type in google  ryzen memory frequency benchmark and check some results.
Just now, the cool guy X_X said:
Can you tell me about the fps difference?
also
https://www.guru3d.com/articles-pages/amd-ryzen-ram-scaling-effect-in-games,1.html
https://linustechtips.com/topic/1250235-is-it-that-difference/#findComment-14049767
If you want to save more money, the 2666 is still ok to buy, you can overclock it to 3000 (even 3200 if your lucky) easy.
Read reviews on the model for overclock ability, memory OC has never been easier nowadays.
Any decent module can jump 1 step, so you'll get 3000 for the price of 2666.
https://linustechtips.com/topic/1250235-is-it-that-difference/#findComment-14049866
