Multiplying floating point numbers
Go to solution Solved by WereCatf,
2 minutes ago, Forenman said:
i don't understand why my code aint working
You don't have main(), which is required.
I am programming in c and it keeps throwing exceptions. Trying to read in 4 floating point numbers then multiply them in the formula "result = ax^2+bx+c", i don't understand why my code aint working..... i keep getting the exception
Error    LNK2019    unresolved external symbol _main referenced in function "int __cdecl invoke_main(void)" (?invoke_main@@YAHXZ)    Formula    C:\Users\james\OneDrive\Documents\Year 4\Object Programing\Formula\Formula\MSVCRTD.lib(exe_main.obj)    1
#include <stdio.h>
int function()
	double x, a, b, c, result;
	printf("Enter value for X:");
	scanf_s("%lf", &x);
	printf("Enter value for A:");
	scanf_s("%lf", &a);
	printf("Enter value for B:");
	scanf_s("%lf", &b);
	printf("Enter value for C:");
	scanf_s("%lf", &c);
	result = (a * pow(x,2)) + b * x + c;
	printf("result is = %lf", result);
	return(result);
https://linustechtips.com/topic/1249916-multiplying-floating-point-numbers/
